Carburators - NCRS Discussion Boards
Carburators
  • Terje Steingrimsen
    Carburators
    I have a 1972 350/200 coupe, assembled in August 1971.
    I am investigating the #matching. It is suppost to be a #matching car, but
    i do not find out regarding the carburator.
    The engine block is #matching, and also the TH400 autotrans.
    The numbers on the Q-jet carburator manufactured by Carter is
    left(vertical)9037S
    right(vertical) 2629
    I can not see that these numbers fits to numbers
    descibed in MF Dobbins or other info books I have(Tom Falkoneer/Rochard Prince).
    Does anybody have the explanation
    Best regards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Carburators
    the number that should be stamped vertially on the driver side above the secondary throttle shaft for your corvette would be 7042202 for federal emissions or 7042902 for calif emissions with auto trans. 9037S is a carter number and over the years rebuilding Q jets i have seen these type of numbers stamped on Q jet carbs. i think that these carbs are either carter factory rebuilds or new over the counter auto parts Q jets sold by carter. this is just a guess on my part as i have never found anything to back me up.
    • Harmon C.
      • August 31, 1994
      • 3228
      Re: Carburators
      The 2629 may be the date code. 262 day of 1979-1989-1999?
      Lyle
        Re: Carburators
        Terje-----
        Some original, PRODUCTION QuadraJets used on Corvettes were manufactured by Carter. However, the one that you have is a SERVICE carburetor. It was manufactured in 1979 or, possibly, 1989. I don't think that Carter was manufacturing these carburetors as late as 1989, but they may have been.
        Usually, Q-Jets, regardless of manufacturer, sourced through GM or Delco will carry a GM part number beginning with "7" or "17". So, I expect that this carb was otherwise sourced. But, it may very well be an exact duplicate of the original or a proper SERVICE unit for your application.
        • Robert Willis
          Re: Carburators
          The Carter (Q jet) carbs that I have worked on all had the number on a round metal tag that was located on the right (Passenger) side of the carb. As I understood it , Rochester couldn't keep up with production needs so Carter built some to Rochester specs . These carbs were installed on the assembly line.
          Bob
            Re: Carburators
            Bob-----
            Yes, many Carter-manufactured QuadraJets were used in PRODUCTION; they were, by no means, a SERVICE-only carb.
            • Harmon C.
              • August 31, 1994
              • 3228
              Re: Carburators
              Carter Qjets are common original on 73's but the correct part number and date are stamped on them. They are date coded only by a letter and a number (A3) Jan. 1973 this dating hase caused some problems for judges looking for a julian date as the roschester carbs had.
              Lyle
              • Robert Willis
                Re: Carburators
                This site may help someone with their carb id's . Bob
