Strut Rod Installation - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I installed the rear spring on my 65 today (Thanks Bill!)and I am in the process of installing the strut rods. I am having a problem aligning the strut rod into the bracket and the rear spindle support casting. The body is off the frame. Should I wait untill the body has been droped on to the frame to install the struts? Will the weight of the body help with the alignment problem?
    Thanks for any help!
    Ray #36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Strut Rod Installation
    We have hashed this many times here. You may find it in the archives, but if you install the strut rods before you load the spring, it is easy.
