I am installing the radio ground wire on my '62. It goes from the passenger side of the radio chassis to the inside rear right valve cover cap screw. Where does it pass through the firewall?
The AIM and ST-12 show it passing through the firewall on the passenger side. Both seem to indicate that it has dedicated hole in the firewall - that it's all by itself, and not with any other harnesses. But the only hole I can find over there is the one up by the coil that contains the ignition harness. Is there another hole in the firewall that maybe I'm missing? The car is up on jackstands, so I can't see real well down there.
