Water pump impeller - NCRS Discussion Boards
Water pump impeller
  • John M.
    • January 1, 1999
    • 1553
    Water pump impeller
    I am rebuilding an old original water pump for my 60, and the rebuild kit has the newer style stamped steel impeller. Does anyone know which impeller flows better, the original cast one or the stamped steel one?
    Regards, John McGraw
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Water pump impeller
    use the CI one but if you use the stamped steel make sure you pop rivet a brass disk to the back side to fill in the openings where they fold over the metal to make the fins or you will have cavatation at high RPMs
    • John M.
      • January 1, 1999
      • 1553
      Thanks Clem *NM*
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Thanks Clem
        if i remember from my pump rebuilding days the clearence between the face of impeller fins and the pump housing is .015
        • John M.
          • January 1, 1999
          • 1553
          Re: Thanks Clem
          I was wondering how close to run it. I know from my industrial pump background, that the closer I run the impeller to the intake volute the more efficient it will pump, but was unsure how close to run it.
