I'm hoping someone can answer some specific questions re this 1958 clock:
1. How long should it run, typically, between electrical rewind events?
2. What is the electrical resistance of the rewind solenoid coil?
3. On the back face, are the seemingly insulated screws wtih tiny nuts supposed to be at case ground?
4. How does one open the case to get at the contacts for cleaning - does the set knob uncrew fron its' shaft, then pry the fascia ring open?
My clock runs ok when I reach in thru the lamp hole and manually actuate the winder; but shows 4-6 ohms when it winds down.
Thanks!
... Al '58 #378 245hp NCRS SACC
Thanks!
