1967 - low beam headlights don't work - NCRS Discussion Boards
  • Mark Silberman
    I repaired both headlight motors and now the low beams don't work. fuse is ok and high beams work. What did I do? Thanks Mark
  • Gerry Proctor
    Re: 1967 - low beam headlights don't work
    If it worked before you touched it, it's probably something you did.;-)
    Do you have voltage at the connectors that plug into the bulbs?
    If you do, then it may be nothing more than a burned out headlight. If you don't then you'll have to trace the wiring back to ensure you didn't disconnect a plug along the way. It could also be your dimmer switch. As long as you don't have to pull the headlight switch or get too far under the dash, it shouldn't be too hard to resolve.
