73, 74 & 75 air cleaner ring mystery - NCRS Discussion Boards
  • Geno B.
    • April 30, 2001
    • 90
    i picked up 6 air cleaner rings yesterday at a junkyard that were in an old school bus full of corvette parts. there were three different ones. all three were completely round. two had 5 slots cutout in them. two had three slots cutout in them. and two had 3 slots cutout in them but the circular top was offset to one side about an inch or so. anyone know which is correct for my 74 and what corvette application the others are for?
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 73, 74 & 75 air cleaner ring mystery
    The offset 1"one is for a 454 the round ones are for 350's. as for the slots two go over the snorkels and one over the plastic breather. Their may be more I will need to look.
    Lyle
    • Harmon C.
      • August 31, 1994
      • 3228
      Also
      The 2 offset ones are 454 and are 73-74 with 3 slots. The 2 round ones with 3 slots are 73-74 with a 350 . That would leave the 2 round ones with 5 slots as 1975 with a 350 but the 75's I can't be sure of as I have no examples.
      Lyle
      • Geno B.
        • April 30, 2001
        • 90
        Re: Also
        thanks lyle, thats about what i was thinking to. i've never seen a 75 ring either to know if it's the one that should have the 5 slots. or, my other thought was that one style might have been for a camaro which also use these.
        • John Wire
          Hmmm.... what are air cleaner rings? It is late and I'm about ready to "call it a day", but I have a 75 which has an air cleaner with two snorkels, a top for the air filter and a rubber seal for the hood induction system. Am I missing a ring somewhere?
          • Geno B.
            • April 30, 2001
            • 90
            the ring is what the rubber seal is glued on to. it is removable from the air cleaner. just pull it out. i would love to know how many slots are cut into your 75 ring and if your sure or not if it's original to the car.
            • John Wire
              My 75 is original. Can't go out and look because it's 200 miles away "hibernating". However, as I recall, the "ring" has at least two notches which allow proper indexing over the two snorkels to ensure the rubber gasket contacts the sloping underside of the cowl induction box correctly.
              The assembly manual shows at least one other notch in the flange ("ring"), in addition to the two for the snorkels.
              Next time I see "OldSlowVette" I'll check it out for you.
              Have a Happy New Year!!
              • Harmon C.
                • August 31, 1994
                • 3228
                Re: Also
                Wasn't the ones used on other GM cars larger in diameter and that is why you need to cut down the replacement rubber ring.
                Lyle
                • Geno B.
                  • April 30, 2001
                  • 90
                  Re: Also
                  you may be right, because the replacement rubber ring is way to big for the 73-74 ring on my wifes 74 vette.
