I read an article from the archive that said to test the amp meter, check for voltage on both leads to the meter. (I have voltage to both leads) Another thread said to check for continuity at the meter. (I have continuity accross the leads)
But, my meter still is dead. Anyone have a suggestion?
This started when a new battery didn't seem to be cranking the engine very well even after running it. I took the alt to the local Auto Zone and they tested it and said it was dead. I have put on the new one and I must say the engine runs smoother. But I still am not sure the battery is being charged.
Can anyone also suggest how a novice might check to see the alt is working and I would guess the voltage reg as well. None of the light bulbs have gone crazy bright so I assume the reg is not letting too much current thru.
Any direction is appreciated,
