I have a'65 with L-79 (350hp) and power steering. I am in the process of restoring the car, frame and driveline is done. I found that in the the judgeing manual that the L-79 has a crank pulley with three grooves. Is the third groove an add-on, or a complete three groove pulley, and if it is a complete three groove pulley, where would I find one? I currently have a two groove pulley and it lines up with the P/S pump pulley. The car is a 4-speed, P/S, P/B with a VIN of 1344. If it does have three grooves, are their three belts? If so, where do they all go. I know that early L-79's had the idler pulley, but probably not the ones with P/S. My water pump pulley has two grooves, currently not using one groove(the #2) is this correct?
Jeremy
Jeremy
