The Tech Manual mentions that the wedge on the upper part of the door is aluminium, that I have on both sides with a shim to each.On the jamb I have an aluminium and a plastic both with a shim.I can't find in the manual what the jamb is to have.(1)Are the jamb wedges aluminum or plastic ? And(2) did they install the shims at the factory? I haven't tried the doors without shims as yet.Thanks ahead for everyones help...
C2 Door and jamb wedges
