My '64 Roadster is equipped with a SHP 365 HP, solid lifter engine. I am doing a complete frame-off.
I'm at the engine stage starting with a compression check. The shop manual calls for 150 PSI. After repeated checks, hot and cold, carb wide open, I'm recording 188 to 195 PSI.
I've removed the heads. Valve diameters are correct and carbon deposits are minimal.Cam lobe lift measured at the push rods is intake .290" and exhaust .320". Manual specs calls for intake .2625" and exhaust .2665". I believe this to be an aftermarket cam and I wonder is this is the source of the high compression.
The engine had been reworked previously and, by all indications, it appears to have been done properly. What I don't know is have the block and or heads been refaced. Are there any benchmarks on the 327 block or heads which would allow me to determine if this has been done?
Perhaps there is a book which can answer my questions. If so, I would appreciate hearing about it.
Thanks very much for your help and Happy New Year!
Patrick F. McInerney
