c2 two part primer sealer removal - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    I have some overspray that is a two part epoxy sealer, it's yellow,on the undercarridge i'm trying to strip with paint remover, Nothing has touched it. I've even tryed the really nasty stuff. Any suggestions on stripper for this type of paint. Jerry
  • Norris W.
    • December 1, 1982
    • 683
    Re: c2 two part primer sealer removal
    My experience has been that most primers don't respond well to stripper. Have you tried the old laquer thinner/scotch bright pad scrub?
    • Jerry G.
      • April 1, 1985
      • 1022
      yup I've tried that. I think I'm going to haave to use abrasive blasting to get it off. It's a sealer that is two part epoxy. Is there a paint expert or supplier out there that has any suggestions.
      • Donald O.
        • May 31, 1990
        • 1580
        Have you tried 80 to 100 grit on a DA? Its cheaper than sending out for plastic media blasting.
