Small Block Oil Pan - NCRS Discussion Boards
Small Block Oil Pan
  • Jim M.
    • October 20, 2009
    • 41
    Small Block Oil Pan
    I have a 327/350 hp corvette built in Early Feb.1965.
    Can anyone tell me if a big(6qrt)oil pan belongs to this car or is it a small (5qrt).
    Jim
  • Lane Ockerman
    Re: Small Block Oil Pan
    Jim,
    The L79 350 hp has a 5 qt. pan indentified by a 10 1/2 inch lower sump.
    Vertical ribs are embossed into the side of the pan, 3 ribs on the left side and two ribs on the right. All ribs are approximately 1 1/2 inches high. The pan drain exits the rear with a thin, flat head 3/4 inch drain plug with a white nylon gasket.
    Hope this helps you.
    Lane Ockerman
    #38102
      Jim-----
      I believe that all 1965 L-79s used the "5 quart" oil pan. Originally, this pan was GM #3820000.
      • Loren L.
        • April 30, 1976
        • 4104
        It seems to me, at least, to depend
        in part on WHEN Power Steering becomes available to the 350 HP engine
        because with the BIG pan, no PS. There is a mid-year announcement in the Chevrolet Service News that announces that " PS is NOW available" with the 350HP, implying at least that it was NOT always so.
