C-1 Steering column wiring removal - NCRS Discussion Boards
  • Don Ursery
    I'm pulling my steering box and stumped on the steering column wiring. The connectors seem to be permanent with the "spade type" wiring into harness connections. Do I just pull them out? Thanks for any assistance. Don
  • Roy Braatz
    Re: C-1 Steering column wiring removal
    Pull apart the connection under the dash, then pull the turn signal housing along with the wires out. The wires are old and stiff.
    • Dennis A.
      • April 30, 1999
      • 1010
      Don,
      If I remember right, On a 61' there are three connectors, (7 wires) Tail light directional, horn, and parking lamps. To remove, insert a small screw diver into the connector to depress the tang and pull the wire. Record the wire locations if you do not have the AIM.
      • Ed Jennings
        There are three connectrs. The two plastic ones have wires with similar colors on the other end, so rewiring is a snap. The horn connection is by itself, and connects to a brown wire coming from the horn relay.
