Glue Removal - NCRS Discussion Boards
Glue Removal
  • Peter Ansted
    Glue Removal
    After washing '63 today, I noticed a small streak of carpet glue on my quarter panel. The glue is the type in a can that you brush on and the car's finish is clear coat-base coat. I just finished installing the carpet last week and all went well before this. Any suggestions on removing this small amount of glue without harming a good paint job is appreciated.
  • Donald O.
    • May 31, 1990
    • 1580
    Re: Glue Removal
    Peter,
    Others will surly chime in, but I'd try mineral spirits, nail polish remover, lacquer thinner or "Goo Gone" (or is it "Goo Off"). Bc/cc is very durable, and after curing almost impervious to solvents.
    Don
    • George Romano
      Re: Glue Removal
      Try some WD-40.
      George
      • Verle R.
        • March 1, 1989
        • 1163
        Re: Glue Removal
        I have had very good luck with Desolvit (sp?) in a spray bottle found in the home cleaning section of your grocery store or Walmart.
        Verle
        • mark34178
          Re: Glue Removal
          Use 3M Adhesive remover which can purchased at auto paint supply stores.
          It works very well on weatherstrip adhesive and other adhesives and will
          not damage the paint. Do not use lacquar thinner as it can soften and
          dull even the newer two stage clear coat finishes.
