C2 Steering Column Correct Paint Finish - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2640
    I'm finishing up the rebuild on my '64 steering column. I had to replace the tube portion due to two of the tangs being broken off and causing a loose condition. Reading my 63/64 NCRS judging manual it states that the entire '64 steering column tube, directional signal housing and steering wheel hub are to be painted a "low gloss" black and the support plate that the column tube passes through is painted a "semi-gloss" black. I painted the hub and directional housing with Krylon brand semi-flat black. When comparing the newly painted items with a portion of the original, unrestored portion of the steering column tube that was located under the dash neat the firewall, the original finish on the original tube has more of a glossy, satin finish. I used Rustoleum brand satin finish on the support plate and it looks okay.
    What brand(s) of paint have been used that is close or closer to the correct color?
    Best Regards,
    James West
    Omaha, NE.
    NCRS #18379
    1964 Corvette #9258
