Overheats only while idling, going down road temp. stays around 170. Newly rebuilt engine with less than 500 miles. Radiator, water pump, hoses, coolant all OK. Pressure tested system and all checked out fine. Replaced temp. sending unit with NOS and put resistor in line and verified temp. at thermostat housing
with IR gun to verify reading at gauge is right-it is. Also installed new 180 thermostat. Still puked antifreeze after idling for few minutes. Replaced 7#
radiator cap with 13# cap, ran 30 minutes and temp. stayed at 170. Will the higher pressure cap cause me any problems if this appears to correct the problem?
