C1 stearing wheel orientation - NCRS Discussion Boards
  • Don Izzo
    Can someone tell me what is the correct orientation of the stearing wheel onto the colum. what I need to know is what position the two rolled pins installed into the hub to cancel the direction signals are in. Do I face them to the left or right. Also does the horn brush contact get installed from the top or bottom side. Thanks!!
    Don
  • Christopher R.
    • March 31, 1975
    • 1599
    Re: C1 stearing wheel orientation
    The steering wheel is installed so that the 2 rolled pins are vertical, on the side towards the outside of the car (where the turn signal mechanism is). Approximately 8 and 10 o'clock.
    The horn brush contact is installed from the top. Clean off the contacts on the column and the brush to that you get a good connection.
