I'm replacing the lower outer bushings on my 62's front suspension. The old pivot bolt was pretty worn and misshapen. The new bolt won't screw into the existing bushing. The old worn bolt had deformed it. So the pivot bolt bushing will have to come out of the knuckle. It went in there 41 years ago with 150-170 ft. lbs. of torque. Since then it's been in the Rust Belt.
Any suggestions on how to get it out? When it was still on the car, a 6 point socket on a long breaker bar with a pipe extension started to raise the car off the jackstands. Now I've got the knuckle and spindle off the car. It needs to go to a machine shop to get the kingpins off anyway. I can't even get the kingpin lock pin out. Any instructions I should give the machine shop to do this work? Anybody know of any machine shop in the Boston area?
Am I going to have trouble getting the new pivot bolt bushing in? Is this something for the machine shop also?
