C1 deck lid latches
  • Peter Cipriani
    #1
    C1 deck lid latches
    Could someone describe the correct type of nut or nut washer combination used under the deck lid latches on a 61?? I've seen different combinations, a separate 12-24 nut and washer, also a one piece nut/with large washer. The JM has no specific details on this. Peter
  • Dennis A.
    • May 1, 1999
    • 1010
    Re: C1 deck lid latches
    Peter,
    A nut, lockwasher, & plain washer are used to mount the Hood Latch to a threaded stud plate that is riveted to the body. If you look at "view D" in the AIM, You will see this detail.
    • Peter Cipriani
      Re: I mean, conv. top deck lid latches
      Sorry for misleading you, I'm talking about the latches that pull the conv. top down on the deck lid. Peter
      • Dennis A.
        • May 1, 1999
        • 1010
        The Corvette Central Rear soft Top Latch Screw set comes with the screws, Nut, lockwasher and a Plain washer. They usually do a good job of matching the original. I have my old set and will check what they were in 1961. (Sorry about the fast reading).
