C 1
  • FRED S. CRAPROTTA
    C 1
    OUT OF NOWHERE, MY 62 BEGAN DOING SOMETHING STRANGE. WHEN I APPLY THE BRAKES THE FUEL GUAGE ADVANCES APPROX 1/8 TOWARDS "FULL". IT EVEN DOES THIS WHEN I AM COMPLETELY STOPPED. I DON'T KNOW WHERE TO START, ELECTRICAL OR MECHANICAL. ANY IDEAS OUT THERE? IT IS A 5 YEAR FULL RESTO CAR.
  • Christopher R.
    • April 1, 1975
    • 1593
    Re: C 1
    Common problem. Lousy ground at the sending unit. The archives will have lots of info on this. Fix is to run an additional ground from the sending unit to the frame.
    • Loren L.
      • May 1, 1976
      • 4108
      This is so common that it probably should
      be included as "REQUIRED" under the "as it was delivered" operations check.
      • Ed Jennings
        Re: C 1
        I am surprised it doesn't also do it when you turn on the signal lamps. Like mentioned, add a ground from the sender flange to an inconspicious place on the frame.
