I have a 65 Roadster I am restoring and have just taken the Gauge Cluster out to rebuild it. Most gauges work fine, just need cleaning and some touch up paint. The big problem is my cluster housing is broken. The corner below the wiper switch is missing so I need a new housing. From everything I can find written, it appears that the housing is the same from 63 - 67, is that correct? Also the speedometer works fine, but the odometer does not. Is there a common cause I should look for? I have seen the odometer drive gear available from most of the catalogs, and one offers a three piece NOS gear set.
Thank you,
george
Thank you,
george
