Information Needed:1965 Corvette Intake Manifold
  • Ray C.
    • July 1, 2001
    • 1124
    #1
    I am in need of information on the base 250HP intake. The NCRS Technical Informational Manual & Judging Guide (Forth Edition) List manifold #3844457 as the correct manifold for the base 250HP engine and 3866922 as “acceptable alternate manifold.” I have had talked with Gene Manno in reference to the 3866922 manifold and Gene stated” I have seen more 3866922 manifolds in late 1965 250HP engines then the 3844457.”
    If you have knowledge of, or own a 1965 Corvette with the base engine, I would appreciate the following information:
    1. The engine assembly date.
    2. The casting number on your intake. (3844457 or 3866922)
    3. Casting date code on your intake.
    Please email me at: rcarney5@rochester.rr.com
    Thank you for any help!
    Ray Carney
    NCRS #36314
  • Loren L.
    • May 1, 1976
    • 4108
    '65 #23540 is still in the hands of
    the original owner and has the 922 intake, cast D105.
    • Ray C.
      • July 1, 2001
      • 1124
      Re: '65 #23540 is still in the hands of
      Thanks! Ray
