Info Center on C5 - NCRS Discussion Boards
Info Center on C5
  • Dean Sorenson
    Info Center on C5
    My 2000 coupe is giving me false warnings on the driver information center, both for low fuel and engine oil service. I'm curious of others have had this problem and how involved a cure might be. Resets of the oil life message haven't worked since taking delivery of the car. Technology is wonderful when it works!
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Info Center on C5
    take it to the dealer and he can scan for codes which will pinpoint the problem. i would suggest you check to make sure the battery is not leaking which was a problem on certain C-5s. remove the cables from the battery and look for corrosion on the terminals.
