Re: Gravity method
Gary----
I open all SIX bleeder valves at the same time. I close the valves one at a time when I can see NO air bubbles at all in the clear vinyl bleeder tubes. You have to check the fluid level in the master cylinder regularly so you don't run it dry. However, usually the gravity flow is slow enough that you will have absolutely no trouble keeping up with it.
Gary----
