Hello,
yesterday I inspected a '67 Corvette Convertible. Now I have a few questions:
- The gap between the left back wheel and rear fender differs from the right side gap by approximately 0.7 inch / 2 cm.
- The left A-Arm has one thin shim in the front and two thicker ones in the back. The right A-Arm has 2 thicker shims in the front and 6 or 7 in the back.
Do these two issues point to a possible frame problem/prvious accident or are these observations within tolerance?
- The Muncie Transmission has a casting number 3885010 which is correct for a '67 Corvette. The assembly date reads P0706. Does this fit for a Corvette (I forgot to look for the stamped VIN,grr). Thanks in advance.
Oliver Schoenhaar, # 33229
