Spindle bearing end play - NCRS Discussion Boards
  • John M.
    • January 1, 1998
    • 813
    The service manual says this should be 0.001" to 0.008" On one side I have a choice of 0.0015 or 0.0075. Which is best? The shims come in .006" increments. 67 Convertible. Thanks
    • 15610
    Re: Spindle bearing end play
    Go with what's in spec - .0015". IMO the closer you are to minimum, the better.
    • G B.
      • December 1, 1974
      • 1407
      Fitting spindle shims
      John -
      You can sand shims against a sheet of glass to reduce the thickness a few thousandths. I use 220 grit paper and a 1/4" think sheet of new window glass. It helps to keep the paper wet with WD-40 or some other light lube.
      • John M.
        • January 1, 1998
        • 813
        Re: Fitting spindle shims
        Thanks Guys. I'll keep it close to the low end of the tolerance.
