68 327 Flywheel - NCRS Discussion Boards
68 327 Flywheel
  • John D.
    • August 31, 2001
    • 280
    68 327 Flywheel
    Hi:
    Does anyone know the correct GM part # for a 327, 350 Horsepower flywheel. The engine has a September 29,1967 build date. Is a flywheel date coded?
    Thanks in advance, John
    Re: 68 327 Flywheel
    John-----
    The original flywheel was GM PART #3791022 which may have carried the CASTING #3791021. The current replacement flywheel is GM #366860 which also may carry the original casting number. The latter flywheel is still available from GM for a current list price of $287.90.
    Another flywheel that can be used is the GM #14085720. This is a lighter weight, nodular iron flywheel applicable to 65 L-78, 67-69 L-88, and 70-72 ZR-1. Its lighter weight will cause the engine to rev faster, but will also cause reduced "get-up-and-go" from a stop. This flywheel carries a current list price of $206.91.
    Usually, flywheels are dated on the reverse side. However, it cannot be seen when installed in the car. I'd MUCH rather use a NEW, incorrectly dated flywheel than a USED, correctly dated one. Absolutely. Positively.
