Hello
I just put a new MSD distributor into my c3 and found that my tach does not work correctly. It just quivered without any real readings and then my cable broke. Thinking it was just the cable I replaced it. The same thing happened and upon removing the cable from the distributor I noticed the gear was turning counter clockwise. When I turned the cable by hand counter clockwise the same thing happened, just a quiver. When I turn it clockwise the tach rpm goes up as it should. Is there any explanation as to why the gear would be moving in the opposite direction??
Thanks for any insight anyone can provide.
Alex
Alex
