58-60 Washer Pump Rebuild - NCRS Discussion Boards
  • Joe Maulsby
    Anyone had experience rebuilding the windshield washer pump. Words of advice? I have ordered the rebuild kit from CC. The disassembly was easy. I found out there is a very strong spring inside the pump when I released the retainer ring and the bottom section of the pump shot across the workbench. Parts scattered everywhere. Does the little plastic "plunger" with a small spring on top go under the bottom of the spring? Thanks
