(Message Deleted by Poster) - NCRS Discussion Boards
  • Barney Joe Flick
  • Gerry Proctor
    Re: '70 brake line end fittings
    If your question is about the rubber flex line, then no. It is a cad-plated steel. The only brass component that comes to mind in the whole brake system is the junction block.
    I'm not sure what a ball joint cover is unless you're referring to the boot. I don't know about that one as a "factory original" but you can buy the boots from many sources including NAPA. If you're talking about the splash shield apron, then those are available from all the usual resellers.
