I have now purchased a set of NOS front springs for my 67 small block 3851100 from Dr. Rebuild. After installation I lowered the car and presto-- The same ride height as the other 4 spring variations (28 inches from center of the wheel well to the floor). Again I do not have the bushing washers on the car, the car is sitting corectly on the frame, the spring is in the proper slot in both the spring well and the A-arm, the car will bounce freely up and down. When I compress the spring with a spring compressor I lower the car and can get the correct Z score that corresponds to a fender to floor height of 26 inches. I do not have the radidiator, the seats, or the front bumpers on the car but I dont believe the weight will be enough to get it to sit 2 inches. The car cannot be driven -- but the cars weren't driven at the factory and the cars didn't sit too high. What can I do. I took an old spring cut off a full top coil put it back in in the car and I never got it under 28 inches. With each spring I have gotten the same ride height within 1/2 inch. I need help-- Big time. Everything I can think of has not worked. Please help if you can.
Keith
Keith
