On my way home this afternoon I heard a loud rattle from the front of my 67 big block. Upon investigation, it sounded like a marble in the water pump. The sound continues for about five seconds after the engine is shut off and sounds very much like the steel ball on a roulette wheel. Is it the water pump impeller or a piece of it? The engine was running a little warm but not unusually so for our 80 degree Phoenix weather. I'd really appreciate some advice before I tear down the front of the engine.
C2 Big Block Water Pump
Re: C2 Big Block Water Pump
The sound continues after the engine stops rotating. It sounds like a good size ball bearing rotating in a circular enclosure. It is not the water pump, alternator or power steering as I have pulled all the belts in anticipation of of pulling the water pump. I thought that it might be the lower pulleys contacting the frame but they are stopped while the sound continues. I am relly stumped on this one. The engine is running great.- Top
Is the balancer original, or is it one of those aftermarket "TCI Rattlers"? The "Rattler" is indeed full of steel shot/ball bearings, and at low rpm some of them sound like the inside of an outhouse in a hailstorm- Top
The harmonic balancer was freewheeling like a hula hoop. I can't tell what was holding the outer ring to the center hub. It looks like it was a rubber sleeve but there is no sign of it anywhere. Guess I was lucky it didn't damage the timing chain cover.- Top
And I thought the Corvette Gods were frowning on me! I had just rebuilt the carburetor, had John Pirkle rebuild the broken nose in the starter and installed a new battery when this happened. I don't know what I would have done if what you described had happened. Thanks for the post, John.- Top
