Wiper Arms - NCRS Discussion Boards
Wiper Arms
  • Seth
    Wiper Arms
    Looking fori information on how to remove wiper arm. Need to replace left side. Also, can any one recommend best place to buy new one?
  • Peter J.
    • September 30, 1994
    • 586
    Re: Wiper Arms
    Seth, Most 66 corvettes had brushed stainless steel wiper arms not the shiny like the 65 arms. Some early cars could have had bright finish arms, maybe one of our experienced judges could help with a date As for removing, with out the proper tool get a small block of wood and gently pry up with screw driver around the circumference. I would suggest buying the tool. Hope this helps
    • Peter J.
      • 586
      Re: Wiper Arms
      • Louis R.
        • January 1, 1991
        • 16
        Re: Wiper Arms
        Seth,
        A tool is available or you can make one. It is basically an L shapped tool
        _|
        with a lip on the bottom edge. It shoul hook under the bottom edge of the arm. Then squeze the arm against the longer handle. This will take all pressure off the arm and allow you to lift it off the post. I bought mine at a local parts store.
        Lou R
        • Louis R.
          • January 1, 1991
          • 16
          Re: Wiper Arms
          Seth,
          _|
          Lou R
          • Chuck B.
            • 226
            Re: Wiper Arms
            Seth,
            • Chuck B.
              • 226
              Re: Wiper Arms
              Seth,
              • Chuck B.
                • 226
                Re: Wiper Arms
                Seth, If you vehicle Vin # is prior to 12000 than you should have bright arms after that the arms should be dull. Chuck
                • Chuck B.
                  • 226
                  Re: Wiper Arms
