I stumped! I have pulled the rear spindles on my 67" L79 to rebuild the parking brakes and put new bearings in and it looks like I will be taking the trailing arms off since they need attention. I expected the strut arm and the trailing arms for that matter (when one end was disconnected) to hang down!? I assumed that the bushings in the suspension components were free to spin on the their mounting bolts! They don't!! They are pinched tight and all the rotational movement comes from the rubber bushings that seem to be fixed to the steel sleeves that go through them! Even the trailing arms are pinched so that they didn't drop down to rest on the frame but remained straight out after the shocks and rear spring was disconnected form them! They were held there by the rubber bushings that were obviously pinched and stuck to the trailing arm mounting bolt and the trailing arm itself?? Is this the way it should be??? So that all movement in the rear suspension is from rubber being stretched!???
I'd like to understand how this is supposed to work before I put it back together!! Thanks !!! Mike Arteaga #34566
