Sound Deadener - NCRS Discussion Boards
Sound Deadener
  • Michael H.
    • July 31, 1998
    • 180
    Sound Deadener
    Anyone have any recommendations for a sound deadener to be used on the doors of my 1963 convertible?
  • Randy Swartout
    Re: Sound Deadener
    Assume you are talking about the vapor barrier. Right after replacing my vapor barriers with the plastic sheet type I saw an add in the driveline for a new type vapor barrier that is supposed to also reduce noise (in a convertible?) and comes with a pre applied mastic strip.
    • Michael H.
      • July 31, 1998
      • 180
      Re: Sound Deadener
      I also purchased the vapor barrier you mentioned. I was referring to either a spray or sheet liner for the inside of the outer door panel. 3M makes a spray product similar to Body Shutz for rocker panels and Dynamat makes a sheet product. I used Dynamat under the carpeting along with a thermal barrier material and it works well in that area. Dynamat is rather expensive (about $90 for a kit to do both doors) and would be difficult to install in the section closest to the door hinges.
      • Jim T.
        • March 1, 1993
        • 5351
        Re: Sound Deadener
        You could check out what type on sound insulation GM used on say a 96 Corvette door panel. The sound insulation on my 96 is much better that what is on my 85.
        After I get my 85 judged I might try installing the improved sound insulation.
        • Gary Chesnut
          Re: Sound Deadener
          One of our Texas Chapter members - Tom Ames used spray on bed liner in his 66 driver on the firewall, etc. and it works very well. Gary.... #5895
