C1 Upper Outer Bushings - NCRS Discussion Boards
  • Lee D.
    • September 30, 2000
    • 12
    Does anyone know where one could purchase just the upper outer bushings for a '59. Every catalog dealer I call will only sell me the complete shaft and pin kit. My alignment is fine but my bushings are sligthly worn and have a very small but definite squeak.
    Any help would be appreciated. Thanks,
    Lee
  • Roy Braatz
    Re: C1 Upper Outer Bushings
    Are you talking the camber shaft nuts ?which side greas fitting nut or plain nut side?
    • William C.
      • May 31, 1975
      • 6037
      Since that is a metal to metal joint, if the bushings are worn, the shaft is also, it's no problem to replace the outer shaft once the bushings are out, why not go for the whole deal?
      Bill Clupper #618
      • Mark Malone
        I'm with Bill on the shaft and bushing as a set.
        Try Mary Jo Rohner as she has sold me single items that the others only sell as a set.
        Good Luck, Mark.
        My Vette page!
