I am in the process of rebuilding my brakes, master cylinder, and rubber brake lines and I have a question concerning the order of the components as they go in the bore of a non-power master cylinder on a 66. When I checked the 66 Chassis Service Manual for a schematic of the components, it shows a slightly different set up, using the example of the "Duo-Servos Brakes" master cylinder. Since this set up is slightly different, I thought that I would check and see if anyone has the proper order in the main body bore. When I took my components out, they came out in the following order: rubber boot, retaining clip, piston with a secondary seal just below the first lip, primary seal which was seated over the spring. The spring has a small copper-colored metal cap attached to one end of it and it was inside the primary cap or seal. I am really questioning whether this metal spring should go in against the far end of the bore, through which the brake fluid is pushed, or should this metal cap go against the primary seal?
Does anyone know for certain or have an exact diagram here? Thank you, Gary
