C2 REAR SPRING INSTALLATION - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I am preparing to install the rear spring in my '67. Do I need to wait until it is connected to the training arms before tightening the bolts securing it to the differential?
  • Robert C.
    • December 1, 1993
    • 1153
    Re: C2 REAR SPRING INSTALLATION
    Attach the 4 bolts to the rear diff. and tighten snugly.Jack up, against a clamp on each end of the spring until the out side trailing arm bolt can be attached to the end of each side. Final tighten the differential bolts after the car is sitting on the ground.
