I took the brake calipers apart on my 69, and they are completly gummed up by crud from the combination of dot 3 and dot 5 fluid. I thought I flushed them good, guess not.
When I went to my local Chevy parts dealer, he said the part number for the outer seal part had been replaced by a seal kit which was more than double the cost. I need 4 per caliper. I really only need the outer seal, because the internal seals are intact.
Is he correct, or does someone know if I can get just the outer seal? $112 in extra parts is spendy if I don't need them ($7 per piston X 16 pistons).
Thanks in advance for the help.
Tom
Tom
