? on the centre carb of tripower setup, the 2 end carb linkages meet . The question is , i could use a picture or excellent discription of correct use of nylon spacers and the special bolt used to hold all. Please advise on correct build up of these spacers
a picture would be very helpfull , or describe as best as one can.
I have several nylon spacers and just wanting correct placement , does rear /firewall linkage go on first with spacer in between then front ect,.,. I have no past experience with this setup and don,t see how it effectively opens the 2 other carbs/ends when centre linkage is opened , it seems to only partially open because it does not stay stationary.
