67 MASTER CYL BRAKE LINES COLOR CODED - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    The master cylinder to distribution block lines I find available have "color coded" fittings (blue and green). Is this correct, as original, or does it have to be removed to avoid being judged as incorrect?
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 67 MASTER CYL BRAKE LINES COLOR CODED
    No, the color dyed fittings are good but I've not always seen green and blue. Green and red/orange comes to mind but I'd have to look back on my notes to be sure. The fittings thread size is different on the two ends as I recall, again I'd have to check.
