Gold stripe color on reproduction tires - NCRS Discussion Boards
  • G B.
    • December 1, 1974
    • 1407
    I've been discussing this subject with Diamond Back Classics for the last few months. I thought that the gold color was not right on their radials. I painted a sample to show them the gold color on two original goldline tires I found. That color was more dark brown than their medium yellow shade.
    DBC told me their color was selected to match the gold rubber found beneath the dulled surface layer of an original tire. I didn't really believe the stripe would darken much from exposure, so I set out to find an original tire to cut up.
    A few weeks ago I bought a bald and cracked original U.S. Royal goldline tire on eBay. I paid $25 plus shipping. I thought it was a bargain if it proved me right and Diamond Back changed their color to match what I wanted. However, I was proven the fool once again.
    The cut-up sidewall told a strange story. On the surface, the stripe color appeared to be the same brown-gold that I had seen on the other old tires. But cutting into the stripe revealed the truth. The never-exposed rubber was not brown-gold, but a much lighter tanish-yellow color. It turns out Diamond Back's gold color is much closer than I ever thought. It is a little more yellow than the original, but not by much.
    Rats. What happened to all the knowledge I had when I was 18? I was right about everything then.
  • Brian M.
    • February 1, 1997
    • 1837
    Re: Gold stripe color on reproduction tires
    Hey Jerry, I have a set of Gold Line bias ply tires that I'd like to change to Redlines. Do you know of any way of doing this on a budget? I've tried to locate a red tire paint to no avail. Regards Brian
    • G B.
      • December 1, 1974
      • 1407
      Long story short: no.
      There are several companies who can vulcanize red rubber onto your existing sidewall, but I doubt that kind of work will be found at "budget" prices. As for painting them... you were joking, right?
      In your shoes, I would sell the goldline tires you have and then buy some new redlines.
      • Brian M.
        • February 1, 1997
        • 1837
        Re: Long story short: no.
        I figured the sell and buy method was going to be the way to go. Thanks
        • Chris Pergola
          Brian,
          I believe Kevin McKay has a guy who will change out the gold color for red using paint. He recommended it to me for changing red lines over to gold so I would have to imagine it would work in reverse.
          Let me know how you make out.
          Chris
