I have a silver 435 coupe #7606 that I took apart 17 years ago and just put the body back on and now brakes ,it has the j-56 antilock valve under the propotioning valve and my tank sticker, which is very tattered says it has
j-50&j-56 .
What is the casing number for the j-56 master cylinder with j-50. I was thinking mine was the original till now,almost everything else is, but I guess not. It is a replacement? #5460346 stamped "PG".
Where can you get the j-56 brake pads.Are they still available I called a couple parts stores and no go, My calipers have been changed to vette/brake ground off casings,restamped ss standard one pin type calipers.But was thinking about adding the j-56 calipers back on now that I know about them.Since it came with them originally.
And the rears are just standard nothing different one pin calipers with the
J-56 option? I saw a set of four J-56 calipers front and rear for sale on ebay what car did they come on.
What books can you suggest for reading up on the part numbers for my car, its time to check them out, I guess I need to do some research.
Below is a couple pictures of my 67 and 62 #350
My 67 L71 coupe pics
j-50&j-56 .
