C1 Tie Rods - NCRS Discussion Boards
C1 Tie Rods
  • Christopher R.
    • March 31, 1975
    • 1599
    C1 Tie Rods
    Trying to decide whether to replace the 4 tie rod ends on my '62. They might be original. The inner ones have a big dab of blue paint on them. The grease fittings are on the side.
    I'm chasing front end wander and steering sloppiness. Some control arm bushings were worn and have been replaced. Both kingpins were replaced. The steering box is adjusted pretty good. Lord knows where the alignment was, but now it's worse after the bushings and kingpins replacement. When the snow's gone, it's going to an alignment shop. While it's at the shop would be the time to do the tie rod ends.
    How do you test tie rod ends? There doesn't seem to be any side-to-side movement. But it's hard to be sure. However, they are very loose. That is, they will very easily move and swivel. I know they're supposed to do that, to allow for changes in their plane of operation when turning. But newer ones I've operated are somewhat stiff. Mine move almost too easily. I'm wondering if that's am indication that they are worn.
    Second question: Can these tie rod ends still be purchased at a well stocked local parts store? Or, is it necessary to get them from a Corvette specialty house? (I know about Kanter.)
    Third question: Did the originals have the grease fittings on the side? Or, in the bottoms? I see Moog tie rods on EBabe regularly. Will they pass judging?
  • Roy Braatz
    Re: C1 Tie Rods
    The grease fitting were on the side ORIGINAL and the cost is low for new ones, check out www. classicchevy.com, same as car. .There is one thing I would check , that is the DRAG link for wear and ajustment, this could be your problem many people over look it. Both ends are spring loaded.
    If your useing original repro. tires , Change your front wheel BALL bearings to ROLLOR bearings and you will think you added Radial tires.I posted a note about them , but don't know how you would find it.
