C2-ROCKER MOLDINGS - NCRS Discussion Boards
C2-ROCKER MOLDINGS
  • MIKE LUONGO
    C2-ROCKER MOLDINGS
    I AM finishing restoration of 1963 coupe: The original rocker moldings and the body measure 66" I had purchased a new set and put the passanger side on and it was 1/2" short? Called supplier and they told me to measure the body and the original rockers from longest points. car is a no hit all original body panels.
    the supplier measured a set they had in stock also measured 65 1/2" please advise if someone can restore the origianls or is their a supplier for nos?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2-ROCKER MOLDINGS
    Amazing isnt it, that anyone would go to the great expense to tool up to repro a part and then do it wrong.
      • 11608
      Wayne,
      I'm amazed any more when they do it RIGHT.
      On a similar note, the reproduction 70-77 rocker panels are made WITHOUT the original mounting tabs. Instead, they are like the later GM replacements. Not one of the 3 (yes, three) companies that has tooled these up has made them correctly.
      Patrick
