Just hooked up the headlights on my 63 and they don't work. I put a volt meter on the wires and get no reading on tan&blk or grn&blk on either side. It was suggested that it might be the dimmer switch. Any advice on how to check this switch or what else to check? All new wiring and new light switch.
C2 Dimmer Switch
Re: C2 Dimmer Switch
Gary, an OHM meter should do. There are three contacts. One upper and two that are side-by-side. Place the leads from the meter, one on the upper and one on, one of two that are side-by-side. If there is no reading, push the button as if you were changing hi to lo. If there is still no reading on the meter, I think you have a problem. It is a $13.00 part
I just tested a new one and it worked fine.
Harry- Top
