64 Amp Gauge Stuck Below Charge? - NCRS Discussion Boards
  • Dennis M.
    • April 30, 1988
    • 160
    When I installed the Gauge Cluster in my '64 all gauges were showing normal positioning. After this was completed and new wiring harness installed and engine was restarted, I noticed that the amp Gauge was pegged below dis-charge. Even after turning off the engine and turning off the battery cut-off switch. Before I attempt to repair or replace the amp gauge, I would like an idea of what may have been the source of this problem.
  • Richard Hayes
    • Dennis M.
      • April 30, 1988
      • 160
      Re: 64 Amp Gauge Stuck Below Charge?
      Richard,
      I checked and the gauge is not fried, but I do have 12 volts on both terminals of the connector. I am almost certain that I installed the engine harness as the wiring diagram and assembly manual showed, but I guess I must have one crossed up. The other thought is if there is an error in the disgram?
      Any thoughts, I will look over the wiring diagram while I watch the race.
      • Dennis M.
        • April 30, 1988
        • 160
        Richard,
        I re-checked the pathes of the two wires and re-fastened these connections and it appears to be ok, with the exception of getting the gauge re-cal'ed.
