66 Fan Shroud Revisited - NCRS Discussion Boards
  • Gary Schisler
    In talking with a couple of others about my 66 fan shroud one more question comes up. My 66 judging manual clearly states that it should be semi-gloss black. Another member with a 67 states that his judging manual calls for natural fiberglass, varying in color from dark grey to black. My judging manual is 6 years old. Is there really a difference between the 66 and 67 or is my 66 judging manual out of date? Do any of you have a newer or more current manual?
    Thank you, Gary
  • Pete M.
    • February 16, 2011
    • 21
    Re: 66 Fan Shroud Revisited
    Gary, Fall of 1994- [ 1966 judging manual] States shrouds should be semi-gloss black as my late (june)car is. Hope this helps
    • Pete M.
      • February 16, 2011
      • 21
      • Gary Schisler
        Thank you
        Thanks, again.
        • Gary Schisler
          Thank you
          Thanks, again.
          • Carl R.
            • March 1, 1998
            • 166
            Re: 1967 327 shrouds
            Being that other member - tell me - is mine correct?
            Winter 1997 manual states 1967 327 shroud natural fiberglass "varying in color from dark grey to black." Unfortunately did have to paint mine semi-gloss.
            ...which is "correct"?
            Carl
            • Carl R.
              • March 1, 1998
              • 166
              Carl
              • Gene M.
                • April 1, 1985
                • 4232
                Gary, there has been alot of conversation on fan shrouds on the judging field. The replys you have recieved are correct for 99% of the cars. I have seen 66 cars that appear to be original (under all that grunge) that had unpainted shrouds. I'm telling you this just out of interest.
                • Gene M.
                  • April 1, 1985
                  • 4232
