C2 Engine backfire - NCRS Discussion Boards
C2 Engine backfire
  • Mark F.
    • March 1, 2002
    • 174
    C2 Engine backfire
    Recently acquired a '65 with a CE 402 engine equipped with a Q-Jet carb. The car had been sitting for five years. When it initially started, it ran fine to 3000 rpm, which is as far as I was willing to take it.
    On the second day of my ownership, I noted a backfire through the carburetor whenever I would depress the throttle above a crusing speed. In other words, at 60 mph it ran fine, but when I accelerated it would backfire throught the carb.
    I changed the plugs, points, and condensor; no help. Friends opine that the cam has gone flat, or there are intake valve/spring problems.
    Any opinions as to the problem are, as always, greatly appreciated.
  • Roy Braatz
    Re: C2 Engine backfire
    As you add power a miss is usley a spark plug or plug wires.
      • 15610
      If I assume correctly that the backfire occurs just as your depress the throttle part way and then the engine picks up and accelerates, it's probably a transient lean condition. A larger pump shot might be the answer.
      Try to find out what engine the carb was originally calibrated for. If it was a smaller engine, the pump shot might be inadequate. Also, the manifold could be a factor. A large high rise or single plane will need a bigger pump shot than a more conservative production type manifold.
      Also check the ignition. With a dwell meter installed, rev the engine up high and check for dwell variation. If it's more than 2 degrees the distributor needs a good overhaul and blueprint.
      • Clem Z.
        • January 1, 2006
        • 9427
        sounds like a cam lobe gone to me if it backfires at full throttle thru the carb. run a compression test or take off the rocker covers and spin the engine to check the valve movement
        • Wayne C.
          • November 1, 1978
          • 289
          May simply be that the accelerator pump has failed... worked OK at first, but broke after some use.
          Also check that the distributor centrifugal advance mechanism is moving smoothly... a little lube might help.
          And check to make sure the timing is set correctly... that the base clamp hasn't loosened.
          • John R.
            • September 30, 1999
            • 288
            Wayne may be right as I had the same problem with my 67 L36 last month. Turns out the accelerator pump was inoperative. I can't believe how well the car runs after replacing the pump and cleaning the carb.
            • Rich G.
              • August 31, 2002
              • 1396
              It could be a lot of things as others have said, but for what it's worth I had a similar issue with a 66 L79 I got in september. It had been sitting for over a year. After a few days and a hundred miles, the backfiring thru the carb went away. It has run great since. I would check the easy things and drive it a little more.
              Rich Giannotti
              • Mark F.
                • March 1, 2002
                • 174
                Thanks, guys, for your quick responses. *NM*
